Mustang Mach-E Battery technology
Battery technology keeps you running with hassle-free charging solutions
Mustang Mach-E will be available in both standard-range (75.7 kWh lithium-ion battery) and extended-range (98.8 kWh battery), which has a targeted WLTP driving range of up to 600 km (more than 370 miles) in rear-wheel drive configuration.
These advanced batteries feature 288 lithium-ion cells for the standard-range specification and 376 lithium-ion cells for the extended-range specification. Designed to help maximise interior space and contribute to optimised driving dynamics with a low centre of gravity, the battery is located on the floor between the vehicle’s two axles – and tested at temperatures as extreme as minus 40 degrees Celsius. The batteries are secured inside a waterproof battery case surrounded by crash absorption protection. The battery uses an advanced active liquid heating and cooling system to regulate temperatures for optimised performance in extreme weather and to improve charging times.
As electric vehicle owners do 80 per cent of their charging at home, Ford offers a Ford Connected Wallbox solution, delivering up to five times the charging power of a typical domestic socket – meaning customers can add an estimated average range of 62 km (38 miles) per charging hour, based on extended-range, rear-wheel drive configuration. The Ford Home Charge Cable, included with the vehicle, can add an estimated average range of 14 km (9 miles) per charging hour using a typical European domestic outlet.
The connected navigation system will identify up-to-date public charging locations during trips and prompt owners to charge at the most convenient points on each drive – all to help ensure they don’t have to be anxious about how much range they have.
Ford also makes charging at home or on the go hassle-free by providing multiple home charging solutions and by giving customers access to the FordPass Charging Network. In partnership with NewMotion and using connectivity delivered by the FordPass Connect on-board modem, the FordPass app will give customers access to Europe’s largest – and fast-growing – network of more than 125,000 public charging stations in 21 countries. Customers will be able to seamlessly utilise charging points across many markets, initiating and paying for charging services from a single account for a simplified ownership experience. A Ford Public Charge Cable is also supplied with the vehicle.
Ford also is a founder member and shareholder in the IONITY consortium that aims to build 400 high-power-charging stations in key European locations by end of 2020. This enables a significant reduction in charging times for all-electric vehicles compared with existing systems – ideal for long distance journeys. With peak charging power of 150 kW, the Mustang Mach-E with an extended-range battery and rear-wheel drive can add driving range of up to 93 km (57 miles) within 10 minutes of charge time on a DC fast-charging station. The standard-range Mustang Mach‑E is estimated to charge from 10 per cent to 80 per cent in approximately 38 minutes while charging on a DC fast-charging station.
“The Mustang Mach-E is the start of a new era for Ford and we could not be more excited to bring it to our customers in Europe,” Rowley said. “This all-new vehicle represents so much more than just zero-emission driving: it’s about stress-free experiences and total peace-of-mind for all-electric vehicle owners.”
