Mustang Mach-E has a maximum 459 horsepower and 830 Nm torque
The Mach-E more than worthy to bear the Mustang name, with its maximum 459 horsepower and 830 Nm torque (Mustang Mach-E GT and GT Performance Edition only) courtesy of a 757-kWh battery and rear-wheel drive provided by a single permanent magnet electric motor and a second motor that adds all-wheel drive capabilities. The available extended range battery pushes the car to a range of plus-minus 500 kms.
When it arrives in late 2020, Mustang Mach-E will be available with standard and extended-range battery options with either rear-wheel drive or all-wheel drive powered by permanent magnet motors. Equipped with an extended-range battery and rear-wheel drive, Mach-E has a targeted EPA-estimated range of at least 300 miles.1 In extended-range all-wheel-drive configurations, Mach-E is targeting 332 horsepower and 417 lb.-ft. of torque – with the standard all-wheel-drive variation targeting quicker times to 60 mph than the base Porsche Macan series.
Ford also will offer two special performance versions. The GT is targeting 0-60 mph in under 4 seconds, making it faster off the line than a Porsche Macan Turbo3. The GT Performance Edition, meanwhile, is targeting a comparable 0-60 mph in the mid-3-second range to a Porsche 911 GTS. Both GT configurations are targeting an estimated 342 kW (459 horsepower) and 830 Nm (612 lb.-ft.) of torque.
